주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
592 질문 전체 보기
No display after water damage.
I received a Macbook today for repair, it was water damage and they told me someone had fixed the water damage. But now there's no display.
I plugged in into a monitor earlier and the screen came on and stayed on, but after removing the battery the screen isn't coming back on and external monitors aren't working.
I'm guessing it's the GPU or the inverter, any ideas?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
GPU - inverter does not affect external monitors. If there's no image on an external monitor the GUP (logic board) is shot. It must be replaced.You should be talking with your vendor (unless you damaged something when you removed the battery).
You're positive the machine is booting up and no video is the only problem.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I woke up today and it came on, got a feeling it's going to go off again. It's waaaay out of warranty so it's not even worth taking it to Apple, for the prices they charge the customer could buy a new laptop. I'm going to get the GPU reflowed and/or rebelled by a professional.
댓글 달기
귀하의 답변을 추가하세요
Liam Hing 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 443
