Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
596 질문 전체 보기
What is the shipped memory configuration?
To increase my 2GB memory iMac EMC 2210 to 4Gb I will need 1, 2GB memory stick or 2, 2GB memory sticks?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Here's the EveryMac specs for your system: Apple iMac "Core 2 Duo" 2.4 20-Inch (Al) Specs
As you can see the system comes with 1GB of RAM (using one 1GB module). In your case your system has two 1GB modules for 2GB total RAM. Your system only has 2 memory slots.
Your choices are: To remove both modules and put in two 2GB modules to get to 4GB of RAM (which is what you asked). Or, you could also go up to 6GB by using one 2GB and one 4GB modules. Which is the systems limit
In any case I would recommend upgrading your EFI to the latest version for your system. Follow this Apple TN on how to do it: EFI & SMC firmware updates for Intel-based Macs.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
tompryts 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 89
