모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
538 질문 전체 보기
Broken power connector for speakers on logic board
After reassembling everything after cleaning up from a liquid spill, I managed to break the connector on the logic board that attaches to the red and black speaker cable.
Would this be fixable by re-soldering the connector (the individual pins look extremely small)? If not, I'm not too concerned about having sound. My next question would be, is it safe to wrap the connector in electrical tape and run the laptop like normal?
Here's iFixit's image of the cable & connector:
Here's my cable & connector in its current state with a screwdriver pointing to where it should be.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
Generally, unless you are in the computer/small electronics business, logic board component soldering is not a DIY project. It requires special tools, solder and lots and lots of practice (it's easy to destroy MLBs with too much heat).
A small electronics/computer repair shop might be able to do this for you.
A workaround would be to use a USB audio adaptor or USB voice quality headset & microphone. USB audio works separate from analog audio.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Patrick Smith 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 16
전체 시간: 510
