2006 중반기/ 모델 번호 A1181 / 검정 또는 흰색 케이스 / 1.83 or 2.0 GHz Intel Core Duo 프로세서.
516 질문 전체 보기
Why does the RAM work in one MacBook and not the other?
I have two Core Duo 2 Macbooks, one with upgraded RAM to 2GB, and the other with the standard RAM cards the Macbook came with.
The second one is in better condition, so I'm transferring parts between the two, but when I put the 2GB of RAM in the better condition Macbook it doesn't work! It turns on, but nothing happens, it stays black.
The one that likes the RAM's serial number: 4H70367MWGL
The one that doesn't like the RAM: W87421ZAZ5V
Please help! Many thanks!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
RAM problems will give you beeps on start up. Both machines use the same RAM, PC2-5300 DDR2.
의 답변
What is the OS version these systems are running? If you are swapping the HD as well here you could have a driver issue as these are not the exact same models (very close though).
의 답변
의견 추가하세요
2개의 답변
선택된 해법
I would also check the firmware versions. It sounds like one has a newer release.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Isn't that on the hard drive though? Forgive me if I'm very wrong. But I am using the same HD for both computers!
의 답변
I really jammed them in too!
의 답변
Check out this Apple TN EFI and SMC firmware updates for Intel-based Macs on the firmware which sits on a EEROM chip on your logic board not on the HD.
의 답변
의견 추가하세요
가장 유용한 답변
Are you certain that the RAM clicked in all the way (sometimes it seems to take an extraordinarily hard push - and that the RAM slots in the better machine are not corroded.
You should try testing one RAM chip at a time, and switch between slots to see it that can point to a bad chip. You could also try one of the 256MB chips in place of the (if identified) 1GB ones.
Just a thought … are the HDs the same size, is there at least 20% free space for VMEM on the one you're moving the 2GB RAM to. More RAM requires more VMEM
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I not only swapped my RAM, but my hard drive too, so it was the same setup for both. On the better machine, when I put the old RAM in, it booted up with that hard drive, so it is definitely the RAM. I'm using the 1GB RAM now, and under system profiler it says they're fine. They work in my battered machine. Thanks for your reply!
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Oliver Revolta 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 122
