Not powering on. Tried known good AC adapter. Light on the adapter.
I replaced the DC jack but still not powering on.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Why did you replace the original? Liquid spill? Fall/drop? - battery not charging?
의 답변
liquid spill. Unknown what type of liquid. No visible corrosion on logic board or DC jack.
의 답변
의견 추가하세요
1개의 답변
선택된 해법
Aside from corrosion (check both sides) you must look for burn marks and swollen components. Use a magnifier. You could try using the jumpers to boot if you have a known good, charged, battery. You could try putting the battery in MacBook Unibody Model A1278
2 GHz (A1278) or 2.4 GHz (A1278) - uses the same battery.
If this Answer is helpful please remember to return and mark it Accepted.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I looked very closely for burn or corrosion marks but could not find any. The customer decided to buy a new computer instead of wasting more time and money on it. Thank you all for your suggestions.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
dkillian 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 140
