Won't power on with charger or battery
A while back, my Macbook stopped powering on (after going to sleep). There's no boot whatsoever--no fan noise or anything. I took it to the Genius Bar, and they wouldn't touch it because it was "vintage." I replaced it with a Macbook Pro this summer, and it's sat on a shelf since then.
Fast forward to now, and I'd love to get it up and working again for my kids to use for Minecraft and some web-based games. Basically, before I order a new logic board, I'd like to make sure I've exhausted my troubleshooting options.
This is what we've done:
1. Tested it with and without battery. The Magsafe adaptor glows a bright, solid green.
2. Reseated the RAM.
3. Taken the case apart and checked ribbon seatings.
4. We checked the power pads with the multimeter and they weren't getting a reading at all. I cleaned the terminal on outside of the case with rubbing alcohol, and now we're getting 0 and 3.42. (That all being said--it's possible my husband was doing the multimeter wrong.)
5. Bridged the jumper pads to short it and start it up.
It's an A1181, by the way.
좋은 질문 입니까?
댓글 1개
Bridging the pads did or did not work? If that didn't work the logic board is shot. Only you know how much $ you want to put into this machine - maybe you'd be better off parting it out for repair and taking that money along with what you'd spend on a new logic board to purchase a newer gently used MB.
originalmachead 의
