주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2170 질문 전체 보기
no sound and no mic after replacing home button
I have replaced the home button on the iphone 4s and now there is no sound and the mic for incoming calls is nit working.
What have I done wrong? I have also tried to change the below part with the speaker and the mic but still nothing
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
의견 추가하세요
답변 2개
가장 유용한 답변
The mic is on the charging port cable that you plugged the new home button into, you could have possibly damaged that cable or its not plugged in correctly, and the speaker is under the logicboard, make sure the contacts on the speaker is making contact with the board. When you changed the black piece at the bottom you only replaced the loud speaker not the microphone.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Happy new year. Thanks everyone. I have changed the charging port as suggested and now sound and mic works!!!!
But after testing the phone the camera is nit working. It is completely black although it shows the choises on the bottom and you could swap to the front camera that is working. The shutter is not anywhere and that makes me worry. I have done restore and hard reset but still nothing. Do you thing if I will change the camera it will work?
Thanks
의견 추가하세요
You may have damaged the connector on the logic board. Post pictures of the logic board and the phone.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
giannins 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 206
