주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2191 질문 전체 보기
Wifi very weak after screen repair
After i self repaired the screen on my IPHONE 4S..not 4, I have looked at the solutions/tips, and they were allf or iphone 4. Wifi still works, just very weak, I have to be literally 1-2 feet away from the router for 2 bars of signal.
Could this be due to loss of some screws/wrong screws in different places. (wasn't thinking of wifi/or things with the phone, was really just trying to get the screen fixed.) Now, i use 4g for "wifi" uses. Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
If it is 4s
Right next to the connectors of the lcd/digitizer to right is you wifi atena covered by a metal cover check if it's connected properly
If it's a4 it's a different problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
So, are you talking about the wifi grommet? Pictures would help also.
For some reason i cant upload pics
But if u want ill email dem to you
But its between the lcd conector and the right next to the headphone jack
just email me, if you can.
Alberto , to add images to an existing answer, use this guide Adding images to an existing answer That way everybody gets to see your answer and you may help a lot of other people out.
bump, bump, bump :P
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
Tony 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 668
