주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
591 질문 전체 보기
Bending Lower Case back into shape
We found an A1286 leaning against a garbage can in Manhattan. The previous user probably had a very hard time removing the lower case since the battery was severely distended.
One corner was severely bent but we took a picture after some bending back by hand. Pictures of the rest of the laptop are here:
https://www.facebook.com/media/set/?set=...
Any thoughts on bending this part back into good-enough shape? If I need to tolerate teeth marks from pliers, I'm fine with that.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Yea that's a mess. You can work it a bit with wooden tools, blocks/sticks and rubber/leather mallets squeeze it in a vice (protect the outside with a soft wood pad), Furniture clamps or C/D clamps (vicegrip)
The problem is the more you work it the more brittle it will become (crack or tear)… also it will deform (stretch). You might see if there are any artist metal workers, or a metal/auto body shop that has some idea's & specialty tools
I'd say give it your best shot to get it close… then maybe leave it be…you could tape the edge to keep out dust/dirt, otherwise you'll have to replace the bottom pan.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
lkvee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,057
