주요 콘텐츠로 건너뛰기
The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 질문 전체 보기
PS3 won't accept a hard drive?
I've tried 5-6 hard drives. It will load up through the menu where it wants to reformat it but regardless of what HD I put in it, it doesn't accept it. I've tried so many PS3 and non ps3 hard drives and I'm at a lack of understanding as to why it wouldn't.
It's like it doesn't want to register it. Any solution to this because it has no warranty?
Model is CECHH01
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
did you try one of those steps?
maybe one of them helps
해당 답변은 도움이 되었습니까?
점수 1
댓글 7개:
markus, you can do better than that limp link ;-)
richard,
you're right - but there are many possible ways to get this done
ok - one trick could be to install windows on the hdd and then put it into the ps3 to format it.
another one is to put it in a larger model and format it there.
next one was formatting it with formatting tools
but i think that there are a few mor infos needed before a possible solution could be found.
what exactly happens when you try to format it in the ps3 ?
does the ps3 the hdd find at all ?
Thanks for the clarification +
Well yes.. I've tried quite a few drives and even reformatted 2 on the computer following instructions on how to do so.
When I put it in, it says you need to reformat this drive and then goes through 2 more pages and stops completely. It finds the drive, recognizes it needs to be reformatted but it's like it can't reformat it. Any ideas?
What hdd did you use? (speed/size). do you try to make a full format or a quick format?
댓글 2개 더보기
댓글 달기
Try formatting the hard disk in format that PS3 supports
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jim Kay 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 25
전체 시간: 6,234
