주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
295 질문 전체 보기
Shifted smart cover magnets, easy fix?
It seems like the upper right smart cover magnet in my iPad air has shifted and is no longer functional.
I used to hear little clicks from my iPad Air whenever closing the Smart Cover or opening it so it wraps all the way around.
I eventually figured out that it was a magnet meant to hold the smart cover clicking when moving around inside the case.
After opening and closing the case several times, it seems the upper right magnet (near the camera) has shifted significantly enough to keep it from holding the smart cover in place while open and wrapped around.
The real issue, however, is that when closed, the rightmost part of the cover simply hovers above the panel!
The magnet must have flipped itself upside down.
No amount of messing about with the cover seems to get the magnet to shift again.
This isn't an issue justifying arduously opening the glued together panel in my opinion, so I wanted to know if there is any other way of repairing this?
I thought about taking a larger magnet and trying to shift the panel magnet back into place, but I'm worried about harming the electronics.
Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
If it's an iPad Air it's under warranty you should take it back to Apple for a replacement.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Would if I could.
I don't reside in the US...
I've contacted the retailer from which I bought it but I don't expect that they'll be too helpful... Which is why I'm seeking an easy fix, if one exists
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
maly 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 2,755
