주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
I have a 2nd HDD but it's just showing as a device.
I have a 1tb HDD in place of my optical DVD drive, I wanted to put my 140gb of music on there and then have programmes like iTunes Traktor etc on my SSD. However the HDD just comes up as a device and keeps trying to transfer all my music to the iTunes folder on the SSD. Now I've tried switching the folder directory and even removing the existing folder from the SSD or just moving the original to the HDD. All to no avail.
Will I have to install OS X on this HDD?
I already have Mavericks running on the SSD
Any help?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Have you done this?
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
I have, I changed my main hard drive too to an SSD so can't do it that way.
Hold down the option key when starting iTunes a dialog window should appear asking you to locate the iTunes library. Pick the location you want. After iTunes finishes starting quit iiTunes. Next time you open iTunes it should "remember" your changed library location.
댓글 달기
귀하의 답변을 추가하세요
Will 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 141
