주요 콘텐츠로 건너뛰기
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
250 질문 전체 보기
Cracked Screen repair : can't find small gap from step 5
After being dropped (resulting in a cracked screen), this iPad was left under pillow that somebody sat on, cracking it further. So I ordered all the necessary tools and parts from iFixit.
I got as far as Step 5, where it says "There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad." Two of us, using a magnifying glass and bright light, aren't able to find any small gap anywhere along the edges, not just "approximately 2.0 inches from the top."
Note that some time elapsed between when I first tried prying blindly at what I thought must be the correct spot and when I got a friend with a bright light and magnifying glass. So the iOpener and iPad had completely cooled off. (I'm not convinced that the iOpener was ever hot enough to begin with.) Does the gap become visible with the application of heat?
Am I missing some crucial step that would cause the gap to become visible? Is there a way to open the iPad without finding the "small gap?"
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
Don't worry about the gap just get the iOpener tool hot enough to heat the glass start at the right bottom and work you way up to the volume buttons, don't pry in this area! then start at the top corner and continue to work around the iPad digitizer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Maggie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 144
