주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
질문 마감됨
black screen after screen replacement won't power?
Hi, I just have replaced my iphone 4s screen but, my iphone won't boot anymore. 5.1.1 is installed on this phone.
All plugs/harnasses are connected correctly.
Any ideas? If I try to update to 6.1.1 my Itunes says error 3194.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
Sorted I have 5.0.1 Ios and original screen sorted the problem thanks all.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You should double check your connectors, also clean them, if you are still having problems you should try another screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks I am on my second screen and nothing has helped yet. Going to try a third screen many thanks.
댓글 달기
It sounds like you may have damaged the battery connector to the motherboard. Try pushing down on the battery connector and powering it on. you may need to plug it in while doing this. If it turns on this is your issue. if not check the 6 contacts to the motherboard around the battery connection to make sure it hasn't been damaged. Let me know if this helps
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
didnt help yet. I have inspected it no damages.
It powers up in DFU mode but, not in normal mode.
no screen black screen flickers. Some people told me ios 5 is causing the issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
iPhone won't power on after repair..
Maybe I have this issue..........
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 199
