모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1448 질문 전체 보기
Won't run on battery
My mother has the Santa Rosa model of the Macbook Core 2 Duo that she received as a work machine. She told me that it won't stay on unless plugged in. I had her check to see if it said her battery needed to be serviced/replaced, it didn't. It only says that the battery is not charging. Does this mean she needs a new battery or that it's something more internal?
It's hard to be more descriptive than that since I haven't actually seen it..but any suggestions would be greatly appreciated. Thanks!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
The self-diagnosis of the onboard battery in a box that old is not that sophisticated. Just as you can't diagnose/fix a car over the phone you can't diagnose/fix a laptop via 3rd party "information". In a machine that age it would not be the least bit surprising that the battery should be replaced.
Before spending money on a battery you really should examine it, run AHT at least, that should give more info about the battery.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Brittney 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 63
