Replace a 5 1/4" HDD with a 3 1/2" HDD?
Apple iMac "Core 2 Duo" 2.4 24-Inch (Al) Specs
Identifiers: Mid-2007 - 24" - MA878LL - iMac7,1 - A1225 - 2134
The HDD on my iMac died. Your replacement guide states to replace with a 3 1/2" HDD but the drive I removed is a 5 1/4". What gives. Does this mean different hardware to mount this 3-1/2"? Does it Have to be a WD. I just happen to have a 3-1/2" Seagate Momentus 5400.6 500gb drive sitting here. Can I use this drive in my iMac. I noticed yesterday it does not appear to support S.M.A.R.T. I hooked it up to my MBP to check it out and erase it. To prep for install to the iMac.
Main question is 5-1/4" to 3-1/2" replacement.
Thank You
좋은 질문 입니까?
댓글 6개
Please give us the last three figures of your serial number (located on the bottom of the stand). Thanks
mayer 의
There are no numbers, just the sticker that states "Designed by Apple" "this item must accept interference from..." etc....
Any other place to look?
Kelly 의
"X8A" found them on the box.
Kelly 의
Thank you Joshua, will that work into the iMac with the snap-in bracket?
Oh, and Mayer, I bet you've never seen a Commodore 64 with external 5-1/4 floppy drive. There's no need for assumptions and statements like that! Maybe stating a large hard drive replaced by a small hard drive would have been more appropriate.
Just sayin', but thanks for the precision.
Kelly 의
Of course I've seen (and used) a Commodore 64 . I bought my first Apple in 1979.
mayer 의
댓글 1개 더보기
