모델 A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5 또는 3.4 GHz Core i7 프로세서, ID iMac13,2
212 질문 전체 보기
Add SSD to a Fusion drive iMac
Hi
I have a 3TB Fusion drive and I just bought a 1TB 2.5" SSD (Samsung EVO 840).
I want to add it to my iMac as my boot disk and make the Fusion as storage.
Is there any way to do so without removing the 3TB HDD and break the Fusion?
I saw this product but than I'll have a useless Blade 128GB SSD:
http://www.ebay.com/itm/SATA-Blade-SSD-M...
P.S
My iMac configuration is:
27-inch, Late 2012
3.4GHz i7
32GB RAM
NVIDIA GeForce GTX 680MX
10.9.1
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글:
Anyone?
I'm the first one to upgrade a fusion to big sdd?
의 답변
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3개의 답변
선택된 해법
Only some models have blade connectors are your certain yours is one that does?
Have you figured out where and how you will mount the SSD there's not a lot of room in there.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
I'm sure.
In your link it shows that every late 2012 27" iMac has it and mine has a fusion drive so it uses it now, right?
의 답변
Yes - my mistake in reading, all 27" models do have it - but there's not a lot of room, how/where are you going to mount the non-blade SSD?
의 답변
I will find a way to fit it in.
In the worst case I will remove the SSD casing.
So there is no way to connect it without removing something?
의 답변
의견 추가하세요
가장 유용한 답변
i did it back than..
I now have 1TB SSD + 8TB HDD (because the original 3TB died).
I used the blade to sata converter + a cable that splits the power from the HDD to both drives.
The SSD fits behind the HDD
http://www.ebay.com/itm/SATA-22-Pin-Male...
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
You have two storage device ports internally. One is a SATA (HD) and the other is a custom Apple blade SSD connector.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
How to set up a fusion drive on the model:
https://support.apple.com/en-us/HT202574
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Oudy Even Haim 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 27
전체 시간: 3,185
