주요 콘텐츠로 건너뛰기
The HTC EVO is a Smartphone by HTC powered by a 1-GHz Snapdragon processor and runs the Android operating system.
71 질문 전체 보기
Dropped phone. Why striped unresponsive screen, yet phone audio and m
I dropped my phone. Now, as I turn on the device, I can hear all the audio activity. But the screen lights up with numerous vertical lines. Some thin, some wide, and some others even wider. Within a few minutes, the screen fades to black. No apps showing, nor am I able to use any of the four icon buttons at the bottom the phone. I can still use the volume, and can hear chimes of when incoming message actvity or other notifications takes place. In fact while its on it even prompts my wake alarm as I had t set before the drop. Can't silence the alarm unless I take the battery off, as there is nothing on screen for me to select. Is there any hope on repairs for this device.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
higonz32, "But the screen lights up with numerous vertical lines" sounds like a broken display. To confirm this, you could post an image of your display with your question. Use these guides to replace the LCD. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
higonz32 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 411
