모델 A1286. 2011년 2월 출시 / 2.0, 2.2, 또는 2.3 GHz 쿼드-코어 Intel Core i7 프로세서
561 질문 전체 보기
Magsafe port failure diagnosis and replacement
I have a MacBook Pro 15" Unibody Early 2011 model A1286. Last night I noticed that the light on the Magsafe head wasn't coming on the the MBP wasn't charging. I went to the Apple store to test a new Magsafe power adapter and the problem persists.
The laptop is experiencing no other issues. The part is rather affordable but I haven't looked at difficulty.
Based on the symptoms is it safe to assume that this is my problem?
Is the repair on this expert level?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
What is the age and state of your battery. If the battery is bad it will not charge. While you were at the store did they check the machine out.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Only you know if you're capable of DIY repair. Purchase the recommended tools (every job is easier when you have the proper tools). STUDY (not just read/skim_ the guide and notes before starting. If it's too daunting check with local repair shops, were into DIY but not every project needs to be a DIY repair, especially if you've never done any small electronics repair or are not a tinkerer...
의 답변
This is a unibody. The battery has given me none of the indications that I've had with laptop batteries in other MBP's I've had going back to the Duo.
There is visible damage to the port. I'm not sure if there was a power spike or what.
The problem occurred yesterday. Prior to that the battery was charging and holding a charge as per normal.
All signs point to the port but I'm curious if I should have any other diagnosis done. With the battery at 4% now I'm not sure how much diagnosis could be done.
의 답변
Replacing the Magsafe board is an easy place to begin... if you're lucky you'll fix it in one go.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Daniel Stra 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 330
