Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1540 질문 전체 보기
Can I use the iPhone 5 charging port on an 5c?
I need to replace an iphone 5c charging port does it use the same of the iphone 5?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
4개의 답변
선택된 해법
No. The parts are different. They are visually identical from the port itself to the headphone jack, but the ribbon cable that connects to the logic board and the two pressure contact points are different. Unfortunately this makes the parts non-interchangeable. You can view both parts on the iFixit teardown for the respective devices.
해당 답변은 도움이 되었습니까?
점수 4
댓글:
Another advert ..mostly for LCD's ... A check of the two charging ports for comparisson cannot be made as I only see the charge port for 5c.
의 답변
의견 추가하세요
해당 답변은 원래 다른 질문에 답변 된 것입니다.
There's a difference, but it's possible.
If you use iPhone 5 charging port you also need the iPhone 5 homebutton flex, then everything will work ;)
I did already 2 iPhone 5c with iPhone 5 charging port.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I dont get it! What is the home flex? I have a 5 parts phone amd a 5c acting up. What do i need to do?
의 답변
The home button flex is on the 5s not on the 5. Nor is it on the 5c. They both have two pin connectors where two brass tabs from the screen side press onto two "Hooks" on the case/board side. I have to try this tomorrow so I will try both.
의 답변
Can you use a 5c logic board in a IPhone 5?
의 답변
iPhone 5 and 5c do not home button flex as such, they have a short connector with two tabs. They don't fit into anything , instead they are "pressed" against two "hooks" when they are assembled.
의 답변
의견 추가하세요
The two charging ports are different. Start at the end of the flex cable. The iphone 5 has a piece cut out to fit a screw. The iphone 5C is oblong with no piece cut out. Beneath the speaker. (The square silver thing) The two contact points on the 5 are on oposite sides of the cable. The 5C has them both together .
Look at the headphone jack on the 5C it protrudes whereas the 5 headphone jack is flush and so won't fit.
Lastly is the screw Tab at the side of the headphone jack. The 5 Tab is right near the front whereas the 5c tab is halfway back. Either way you wouldn't be able to screw it down and for each you would have a screw tab in the wrong place.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
의 답변
No, I will keep it simple, the connections are different places and orientations.
의 답변
의견 추가하세요
can i use iphone 5s chargimg port on the iphone 5
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
asmodeus draco 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 8
전체 시간: 1,951
