주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
모델 PowerBook 1400 Series. 1996 10월 출시
7 질문 전체 보기
Why can't I turn on my PowerBook 1400cs?
On the PowerBook 1400cs 166 Mhz is it possible that the actual power switch on the actual keyboard could be broken therefore preventing me from turning the unit on? If it's not the AC power unit, and indeed is the switch itself, is there a manual available to instruct me in opening up the PB and replacing the switch? Is that part available for purchase, and where can I get the part.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
답변 2개
선택된 해법
Yes. This is the volunteer DIY help form not iFixit customer service to find out what parts are available use the link at the bottom of the page.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
How broken is the button? If their is a white circular, bumped up spot where the button should be, press with your finger on to that spot until you hit the circuit board beneath it, this should work other wise something else is wrong mostly.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Dave Mark 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 690
