주요 콘텐츠로 건너뛰기
모델 PowerBook 1400 Series. 1996 10월 출시
8 질문 전체 보기
질문 마감됨
Why can't I turn on my PowerBook 1400cs?
On the PowerBook 1400cs 166 Mhz is it possible that the actual power switch on the actual keyboard could be broken therefore preventing me from turning the unit on? If it's not the AC power unit, and indeed is the switch itself, is there a manual available to instruct me in opening up the PB and replacing the switch? Is that part available for purchase, and where can I get the part.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Yes. This is the volunteer DIY help form not iFixit customer service to find out what parts are available use the link at the bottom of the page.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
How broken is the button? If their is a white circular, bumped up spot where the button should be, press with your finger on to that spot until you hit the circuit board beneath it, this should work other wise something else is wrong mostly.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 802
