주요 콘텐츠로 건너뛰기
Support for desktop computers by Gateway. Gateway is owned by Acer these days, and anything new by Gateway is supported under the Acer Group.
Gateway FX6860-UR20P won't recognize any of my Ethernet cables?
I just had my computer looked at by the geek squad, they fixed all the problems I was having with not being able to connect to airport networks. It lasted for about a week and started to decline, I decided to switch over to Ethernet so I route a cable from my modem to my computer and hooked it all up. To my surprise nothing occured, no pop ups, no connection. I booted up my Laptop to see if it was my cable, but when I plugged it in almost immediately it connected, provided better connection then just wireless. I'm not sure what the problem is and I'm not sure wether to build myself a new computer or see if geek squad can help again. If you need any more info just ask
My desktop - http://www.newegg.com/Product/Product.as...
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
Launch CMD
It will open a command prompt.. Enter this: ping 127.0.0.1
If you see Packets send and receive it means it's indicated to software issue which may be the drivers.
However, if you see fail or something else, it's hardware issue, that is! Your NIC is dead..
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Well it said ping is not recognized, So I guess my NIC is dead, I barely know what that is, but I know the name. Can I replace it? or am I screwed?
Then your network card is dead, just type NIC on ebay. It's around 5 bucks.
Good luck!
댓글 달기
답변을 추가하세요
TravisC 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 659
