주요 콘텐츠로 건너뛰기
The Nokia Lumia 800 is a Windows Phone smartphone with a 3.7" display and 8-megapixel camera. It is also known as the Nokia Sea Ray. Released in November 2011.
10 질문 전체 보기
The phone was dropped into water, will it ever work again?
the phone was dropped in water - will it ever work again?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개
Don't forget to change the battery after you cleaned your phone properly
My phone has a Crack and yhe screen doesn't work for some reason
My nokia lumia 800 is completely broken water also has got in i need to how i can fix it problrms are
+Screen is completely broken
+battery tray is popping out
+it is not powering on nor charging
Hope u have a fix for this problems
댓글 달기
답변 3개
가장 유용한 답변
Try!
Open it clean the PCB with alcohol and preheat it with a hairdryer. Check everywhere for water. Assemble it after 24 hours.
If you are lucky... :)
Regards.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
thanks very much guys - will have a go
The same happened to me 4 years ago. It automatically shut off itself immediately. At home I cleaned and dried it, First 2 days it was like dead, then started again and is functioning nicely until today ( except the missing app supply, but that's not a fault of that nice phone)
댓글 달기
Dropped a Samsung Galaxy in a sink of water.
Amazingly, the 'phone still worked afterwards ... but it wouldn't charge. Took the back off, removed the Sim card, unscrewed and took off the cover of the charge connector. Then put it on a hot radiator for a day.
It now works a treat.
Key is ... not to drop it in water (obviously!), but if you do, get it out as fast as possible (it's surprisingly well sealed so water doesn't get in that fast), open up as much as reasonable, wipe off any visible water and try to evaporate off the rest.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If your Nokia Lumia phone has been dropped into the water,a good tip is to cover it with rice for at least one day.The rice will absorb the remaining water and the phone will function again.I had that problem and this tip worked.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi,
This link may be of interest to you. You may not be that lucky a second time when trying to use rice and wet electronics
Don't Put Your Device in Rice. Here's Why
댓글 달기
귀하의 답변을 추가하세요
Ted 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 851
