Can you please identify a part for replacement?
I have a iPad 2 CDMA 1397
I need this part Identified so I can order a replacement part.
The part is a very small piece of flex cable that is mounted under either the cellular, or GPS antenna.
The flex or ribbon cable goes through the slot in the frame and there is a connector that has a flip lock, clasp that connects it to the volume/mute flex/Ribbon cable.
The little piece of cable goes through the slot in the frame into the antenna window where the antenna is seated. It goes in, and turns 90*, then turns 90* again with what looks like some type of resistor module at the end of the cable. I added a couple of pictures of where it is located under the antenna.
좋은 질문 입니까?
