주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
3403 질문 전체 보기
iPhone 5 won't boot after disassembly, is my iPhone a paperweight now?
So here's the pre-story: my mom's iPhone 5 has been having problems with the sleep/power button. It wouldn't work at all. So, figuring there might be dirt, etc. causing the problem, I pulled it apart following a guide.
I cleaned everything out, made sure I was being very careful, using all the proper tools (utilizing my brand new iFixit Pro Tech Toolkit), etc. I got everything back together, then powered the iPhone on.
The good news: the power button worked!
The (very) bad news: about 5 seconds into the boot process (showing the Apple logo), the screen dims and some text appears, as if it were booting in verbose mode. Here's the text:
[NAND] _FindFlashMediaAndKeepout:601 physical nand block offset 1
[NAND] start:356 this 0xa3148400 PROVIDER=0xa16f5e80 flashMedia=0xa16f5e80
[NAND] WMR_Start:149 Apple PPN NAND Driver, Read/Write
[NAND] WMR_Start:174 FIL_Init [OK]
[NAND] WMR_Open:371 VFL_Open [OK]
[NAND] s_cxt_boot:88 sftl: error, unclean shutdown; adopted 697 spans
[NAND] WMR_Open:420 FTL_Open [OK]
[NAND] _publishServices:642 FTL capabilities: 0x0000001
[NAND] _ppnvflGetStruct:3469 Checking borrowed blocks - count: 23 max_count: 23
[NAND] _fetchBorrowedList:881 number of borrowed blocks 16
Please help! I really hope this is fixable. From my (minimally educated) look at what I wrote above, it seems like the problem is either the unclean shutdown or physical memory. *panicking* Thank you in advance for your help!!!
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 9
댓글:
Update: found Tyler Farrar's fix over NANDJ_ Find flash media and keep out ERROR FIX!, pulled off the front facing camera connector, now she boots like a charm. I'm going to dig around some more and get back to everyone.
Alright, got everything fixed, for the most part! Thank you everyone for the help! :)
So how did you end up fixing it?
Laurens, he's telling us that it was a flex problem as predicted (read my answer below). Start by isolating which flex is causing the problem by taking them all off except power and adding back one by one.
The best way to repair your troubles is opening over your iPhone,and remove your battery connection for few seconds wait a little bit and reconnect your battery and your screen afterwards and Voila!! you should be all set...Any questions my name is Barri.
1에 댓글 더 나타내기
의견 추가하세요
OPEN ALL THE TABS
RAM Upgrade Kits for Mac
키트 쇼핑하기
Enough RAM
For All The Tabs
키트 쇼핑하기
답변 2개
가장 유용한 답변
NAND errors like that usually look worse than they are. Most commonly they are caused by one of the flexes. If you go back in and make sure each flex is properly seated, and make sure they don't have any traces of finger oils you will likely solve the problem. If this still doesn't work, then you can isolate which flex is causing the error by taking everything off and (starting with power flex) add them back one by one.
Or you could be unlucky like me and find that your first NAND error was in fact a damaged NAND chip :(
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
How to fix..teach me pls me no understand...? Thankz
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Christian 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 22,461
