주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
Why dose screen seem to have white lines appearing in back ground
My screen seems to have faint white lines running top to bottom in the back ground of my screen. On occasion the screen will go black an than come back on its own. When it comes back it still seems to have the white lines? Does anyone know what might be causing this? Thanks for any help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 32
댓글 7개
Thanks for the replies is it possible that a small fall could dislodge this connection? This is my Daughters phone who works at a Vet. She said when she bent down to pic up a dog her phone fell out of her pocket. so it didn't fall to far and worked fine after that. This problem started about two weeks latter while she was sitting down using her phone.
I had two customers with iPhone 5 S same this problem. First one, touch screen was working with white lines and second one , touch screen was not working. Just it needed to replace touch screen chip and I did that and the white lines gone and touch screen start working.
my phone fell now i have the white lines at the top and it is really frustrating as the screen no longer responds when i touch it on a regular basis and occasionally works when the back of the phone is hit on my leg but then shorty stops working
I dropped my iphone 7s in a pool filled with dry ice. It won't turn on anymore. Please help!!
I have an android, never dropped it or banged it on anything. I did download a game and played it for two months they had a few updates after that the lines started on my phone. I did erase the game and all content of it. Same problem, an ideas?
댓글 2개 더보기
댓글 달기
답변 34개
가장 유용한 답변
이 답변이 도움이 되었나요?
점수 5
댓글 6개:
That happens to me to I don't now why if I didn't drop my phone and the white lines are there I tried to turn it of or make your phone die but I couldn't.
when you say touch screen chip do y ou mean the touch screen or the chip on the logic board?
what chip?????????
Touch screen IC on logic board
how much is it
댓글 1개 더보기
댓글 달기
I dropped mine in water but last night the lines weren't there, when I woke up this morning they appeared and they won't go away. I can still touch my phone and everything works right except the lines. They blink in and out sometimes, I've reset my phone, taken the screen off and put it in rice but, the lines won't go away, do I need to go get my screen replaced or what exactly do I need to do?
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
Hey did you ever figure out this issue? I dropped the top half (from earpiece to maybe half way down) of my iPhone 6s into coffee and I immediately dried it and it was fine that day. But today I have faint blur lines, sometimes dense blue lines and then beyond that sometimes a clear screen. Did I damage the lcd or an internal component?
What u did now to this phone
The faint white lines and occasional black screen could indicate a hardware issue, like a loose cable or a failing display panel, or a software/driver problem. To troubleshoot, try connecting your device to an external monitor to see if the issue persists. Using a black screen tool during https://blackscreen.onl/ testing can help you spot the lines more clearly and determine if it's a display-specific issue. If the problem remains, consult a technician for further diagnosis
댓글 달기
How can i get a black line out my phone
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Might just need to repair it
you need to replace the screen, happened to my old phone
댓글 달기
I went to a cave and I put my phone into a waterproof bag and carried with me.. after some water activities I saw my phone was wet and I quickly grabbed my Samsung galaxy j7 prime from the waterproof bag. I wiped it and started to off it because I was scared if any further problems will happen. Then after that, i back sensor was not really sensitive and I tried so many still cannot... Then when I brought to the shop he said the humidity in the air might turn into water vapour and got into my phone screen.. while I and the shop people were talking my phone screen suddenly turned to white grey vertical line.. Can anyone please help me...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Your screen is not seated securely on the logic board, did you have your screen replaced recently? If not then take your iPhone back to Apple for a replacement.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
railmanm,
But would it cost some money?
mine literally just isn't working and im not sure why.. The lines appeared completely out of the blue, but it hasnt been dropped at all recently or in any water damage
Horizontal line appears on my phone travel down and disappear. No fall,nothing and only I updated software...Worried, what could be the reason
댓글 달기
You could try a hard reset or a full restore if it just happened out of the blue..
If it was dropped then it's lcd damage..
But if just happened for no reason then I would get it replaced under warrenty ..
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Had this happen one on a iPhone 5 I was repairing I just unclipped the connectors reseeded and worked 100%
Con how do you do that that's awesome if you see this. Comment plz answer it I need help and I'll be taking
댓글 달기
It could be a screen that went bad. But I just purchased a replacement screen and upon installation the screen was black with white lines. I had just about given up but tried one more time to put it on and it worked. I think the LCD connection is very sensitive and if it's not perfect it will display those lines. Just an observation based on personal expirence.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I replaced a cracked scrren in my phone (5) not s, and the new ones has very, very faint vertical on it, almost hard to see. Just wondering if there is anything I should check, or something I may be able to reseat or tweak to get rid of them???
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I left my phone on all night and I got black lines on my scree what do I do ??
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I don't know what to do
이 답변이 도움이 되었나요?
점수 0
댓글 달기
There is a line on the screen of my phone what can I do to fix.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Yh I need help to
Smash it get new one
댓글 달기
Why are vertical whir lines go down my screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It's either the LCD going out or it got wet. Had mine in my pocket while walking during a heavy down pour within a hour the white vertical lines appeared.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It might have water damage my old phone did it I took it to the phone shop and they said it's got water in the battery there's nothing u can do about it apart from get a new phon
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
If your phone got wet, take the back off and put it in a big ziplock back with uncooked rice, leave it over night. Should help. Good luck
댓글 달기
I dropped my Iphone 6 multiple times but nothing broke. Then a week later white lines start appearing and won`t go. My friend said its a virus but I don`t know. I tried restarting it 2 or more times, its doesn`t work
HELP!! ESAP
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
My brand new phone got white lines around the screen and I haven't dropped it yet or put it on water
댓글 달기
I want to stop the lines on my phone
이 답변이 도움이 되었나요?
점수 0
댓글 달기
When it was raining ☔️ I thought it was in my plastic bag and I dropped it and it was still working at first and then it cut off and then It had a bunch of red and white lines and it still works I'm charging it now
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This is likely to screen connection issue. You need to tear down the phone and properly connect the screen. On an iphone 5, at the top right corner, there should be a metal shield. If you have a toolkit, remove that and firmly press all of the connections. That is my solution.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My phone
Fill in a water and i pulled rice and my phone got line
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
me too in alcohol
댓글 달기
This is happening to me too it honestly helped when i shut my phone comepletlty off and let it sit over night.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I honestly turned my phone off and let it sit.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi yeah you needn’t to replace the screen and put the thing in together as it may be wonky or you could go to woolich phone shop and he pulls fix it for you
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Put it in rice fo 24 hours it should be back to normal if that doesnt work take it to ur phone store.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I did a re-set. Solved the problem on my iphone
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
IPhone reset fixed it
댓글 달기
I have an Android phone, the white lines happened, but I had the phone for 4 years I pushed the amount of gig's alotted for this phone. The bottom line was the screen was going out. Got a new phone, all better. Support always ask if you dropped it or banged it against something, I never did. Sorry If I didn't help.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have an iPhone and a reset fixed this problem with the state lines
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It happens when digitizer connector is not connected on the motherboard or is faulty. You must disconnect and connect that again to solve this problem.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello…this is what I'm seeing on my J6 phone screen. What could've caused this and what should I do?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Was screen ever replaced, or OEM screen?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Mine is too I neeed help
이 답변이 도움이 되었나요?
점수 0
댓글 달기
What can I do when my Android phone have white lines on it?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
please help me how to move them
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It probably is a backlight issue, you would have to order a new backlight or screen, or have a reputable repair store do it for you.
댓글 달기
Hiiiii! Same thing happened to me, I dropped my phone, white lines appeared! I left my phone alone without touching it and a lot of them disappeared! I don’t know if they’ll come back, but for now im grateful it was white lines and not colored lines.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i dont know i have this problem too :(
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
when i use alcohol in my phone the white line appeared help me plss :(((((
water damage :(
댓글 달기
답변을 추가하세요
railmanm 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 12
지난 7일: 19
지난 30일: 32
전체 시간: 213,836
