Screen is cracked and it won't turn on
I have a cracked screen nokia n9 is there anyway to fix a phone like that? It's an internal memory phone the screen is broke and it won't turn on.
좋은 질문 입니까?
좋은 질문 입니까?
I think you may have damaged your LCD while dropping it or the cable became undone.
해당 답변은 도움이 되었습니까?
you can replace the display assembly on a nokia n9. all steps are detailed in nokia service manual.
most of the time a nokia n9 that will not turn on is due to a discharged battery. you can force charge it by using flasher utility.
start the flasher utility, then plug your device and do nothing else but wait. this is a trick to force charge of a nika n9 battery was discharged too low. consider replacing the battery if this happens often.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 1,200
