주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2191 질문 전체 보기
질문 마감됨
Non Responsive iPhone 4s - possessed
Touch screen is non responsive / but if I continue to hold the icon or word - it will eventually go to the next screen. In other words it would take you over 2 hrs to setup the iphone after a factory restore - that's if it didn't automatically put you in a diff. language by default. It has a mind of it's own!!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개:
I have the exact same problem after just a screen replacement. The Phone boots up, normally, however i cannot slide the button on the screen to open it - the screen is unresponsive. It is my sons phone, and I cannot sync it from iTunes since it needs a response from the phone, which i cannot do, since it is locked... I cannot change the time and date in the phone in order to get it out of the searching mode ... do I order a new screen now just to check if this the problem ?? please help, best regards Rene
If you are positive the screen connectors are seeded correctly then yes the screen is faulty
댓글 달기
답변 3개
Try an hard reboot : hold power and home button --> Apple logo,
or restore it with iTunes..
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Done that been there at least 10x - also cleaned all contacts and reseated them at least 4x... inspected logic board - don't see any chip damaged and no water damaged either!
댓글 달기
Sounds like the digi has gone bad. Try replacing it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Just replace the the screen and she will work no problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 163
