Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2976 질문 전체 보기
other pepole can`t hear me
i have a problem with microfone, i can`t hear nobody, i already change the dock with microfone complete new and this option don`t help me. I need change something else? where?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
4개의 답변
선택된 해법
If people can hear you it's not the audio ic chip
I would try another chat hour port it's possible you bought a faulty part.
Try this when you get new part see pic
Actually install it directly without taking the charging port out then insert battery and start up phone the make a call and see if that mic works
It saves you time from taking phone apart if part doesn't work..
I do this with most repairs it saves time if parts faulty
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
가장 유용한 답변
If you can't hear them either and they can't hear you there is a problem with you audio ic chip.. Try this
http://m.youtube.com/watch?v=prSZ9yJnofY
해당 답변은 도움이 되었습니까?
점수 1
댓글:
i try this think and dont help me,
this is what i do for try fixit:
1 change complete connector dock with new mic
2 follow your advies
the strange is i change all things and still the same, i mean i ear the people btu they can t ear me, if i talk hands free they ear me fine or by viver skype etc, what i need to do more?
의 답변
의견 추가하세요
Definitely start with with Con's link. Also, new dock connectors typically have bad mic's. For whatever reason they have really high failure rates. You should check the return policy.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I go try that again like you say, with new part, because I have done at begin, change all dock part inc mic, so I go buy a new item I will try again once thanks I let you know what happens then
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Sodeborla 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 112
