Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3310 질문 전체 보기
Where can I get an iPhone 5 logic board component repaired?
I was recently swindled and have an iPhone 5 with a component missing from the logic board. It's required for the front camera/speaker flex connector. I read about "bare" logic boards on ebay for cheap but they require soldering anyway so I figured replacing one component would be cheaper. I just don't know of a shop that can do this.
http://s1.postimg.org/geokd06rz/photo_1....
http://postimg.org/image/ilj0f43pl/
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
2개의 답변
선택된 해법
Derek, that is reference designator L39. It is a 90-OHM-50MA TCM0605-1 Common Mode Filters(SMD) for High-speed Differential Signal Line. It is made by the TDK corporation. As for getting it fixed, this will depend on where you are. A good electronics repair shop could do it for you, or you may want to contact user jessabethany on here for more help on the soldering part of your job. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thanks oldturkey03! Just knowing which component it is is great. I am in Southern California near Los Angeles (Orange County).
의 답변
의견 추가하세요
I wouldn't be certain on the part you need to replace or if it's a readily available part but I'm sure there's sum1 with logic board knowledge on here that can help you good luck
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Derek 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 1,327
