주요 콘텐츠로 건너뛰기
2.26 또는 2.4 GHz / 흰색 플라스틱 유니바디 인클로저
646 질문 전체 보기
Dual hard drive setup
Unibody Laptop Dual Drive
I want to buy the the optical bay converter that ifixit sell to replace my dvd drive with a second hard drive. I will get a new SSD to put in but thought I should check which of the two SATA connections is faster? The original one that my HDD is connected to or the one the dvd is connected to? Or are they exactly the same? I was thinking if one is faster than the other I should put the SSD in that one.
Also, I may not be keeping this computer for too long. If I buy a new laptop would it be likely or unlikely that I would be able to use this drive adaptor with it? It may not be a Mac so can someone tell me is there a common size for these types of converters? Or (like many other aspects) does Apple have very weird shaped dvd drives compared to other manufacturers so this converter would be useless in a new non-Apple computer?
Lastly, does anyone know which SATA revision this supports? SATA 1, 2 or 3?
Unibody Laptop Dual Drive 이미지
상품
$24.99
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Can you give us the last three digits of your systems serial number so we can correctly identify which exact model you have. Without it we can't really answer your SATA port question.
last three digits: f5w
댓글 달기
답변 1개
선택된 답변
As to the converter being usable in a different system (Mac or PC). the optical drive is a standard device but the mountings of the device is often unique between the different manufactures (across the board). So it likely won't work.
As to the newest version of the iMac or MacBook Pro line the optical drive had been removed in these systems so there is no place to mount it. In addition the SSD devices these models now using a custom blade SSD so your 3.5 or 2.5 SATA SSD won't work.
As to other laptop systems they are following Apples lead here to the newer standard so depending on what you buy it it many not have the option for either the optical driver or support for your SSD either.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Do you know which SATA revision this supports? SATA 1, 2 or 3?
The HD carrier is a pass-though device so the SATA I/O will be what your system is. In this case your MacBook 13" Unibody is SATA II (3.0 Gb/s).
댓글 달기
귀하의 답변을 추가하세요
sam12 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 222
