Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3309 질문 전체 보기
Opening my iPhone failed...
Hi !
I I was just trying to open my iPhone 5 with a suction cup and a plastic opening tool, just like in battery replacement guides, just like I successfully did with other old devices... My problem is that not the entire front display famed when I pulled the cup... The display came alone, leaving the rest (I mean the part where the home button on the iPhone... And I now absolutely do not know how to continue opening it...
You want something worse ? When I pub the display back in, the iPhone does not boot at all...
I'm waiting for your advice to know how to open it now and try to figure out what's going wrong.
Thanks !
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
On bottom left corner stick a flat head scree driver between the metal frame and plastic bezal and pry up
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I succeded opening the iPhone, but as I told before, the iPhone is no longer starting... I thing that the whole front panel assembly and probably other components have been damaged.
Mabe will I try to fix it in a more or less near future but for now I can only tell my iPhone to rest in peace
Thanks anyway I accept your answer because even if my phone is dead, this is probably a good way to open the i5.
의 답변
Hi there have you tryed plugging into iTunes and see if it's recognised?
If so and it's recognised then a screen change could be all you need
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Vincent Monteil 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 81
