주요 콘텐츠로 건너뛰기
Water fixtures and their piping, as well as the myriad of components that keep them flowing.
104 질문 전체 보기
How do l cure water drumming noise?
Early in the morning when the cold water is turned a loud drumming noise develops through the house, how do l stop this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
Clive, sounds like you are talking about "water hammer" First try this
Shut off your home’s main water supply valve.
Open the highest faucet inside your house.
Find the lowest faucet on the property — it’s usually on the first floor somewhere outside or in the basement — and turn it on to completely drain all water from the pipes.
As the water drains from the pipes, air automatically replaces it.
The moment the water is completely drained from the piping, turn off the lowest faucet and reopen the main valve.
Air pushes out of the horizontal and open vertical water lines, sputtering as it exits the faucets inside. However, air remains in the air chambers, eliminating water hammer. from here You also want to make sure that all loose mounting straps for your water pipes are tightened or replaced. Check your water pressure and make sure it is between 30 and 55 psi. Of course you can also get a commercially available Water Hammer Arrester. To read more about the water hammer, check on here. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Clive 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 45
전체 시간: 8,982
