Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3309 질문 전체 보기
Will not respond, battery replaced goes flat and then the same problem
I have recently had three iPhone 5's with the same problem, the problem is that it would not respond to anything tried hard reset and plugging the iPhone in to the mains but still nothing.
However when I replaced the battery it powered up and everything worked fine until the battery ran flat and has reverted back to the same problem.
Just a shout out to see if anyone has had the same problem and to see if there is a fix or not.
Best regards Tom.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
I take it the charger works grand when the phone is on?
의 답변
Yeah the charging port works fine, i did replace the charging port but had the same problem the only thing i think it could be is something to do with the main board. Alas my knowledge of board repairs is quite low.
의 답변
의견 추가하세요
1개의 답변
선택된 해법
Tom, this could be caused by a shorted/failed Charging and USB Control IC Texas Instrument CSD75202w15. It is a Dual P-Channel NexFET™ Power MOSFET which is utilized as battery management and for battery protection. You can download the datasheet from here It is a BGA IC and as such it requires a reball to replace. You may get away with a reflow just to see if it will make a difference. Of course this is only one piece, even so it is a likely candidate, you always want to check your board for any missing, broken or charred components. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
I will try this out next time I have one in, many thanks. Best regards Tom.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Tom 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 147
