Model No. A1367 / 8, 16, 32, or 64 GB capacity
1299 질문 전체 보기
iPod touch 4 will not power on...didn't turn off screen before unplug
So, by mistake, I didn't turn off the ipod before I unplugged the screen. I was testing it to see if I had the digitizer plugged in correctly and when I noticed I didn't, i just unplugged and went to working on it. Not remembering to turn it off first. now the ipod will not power on. Any suggestions?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
4개의 답변
Possibly shorted something. Have you tried a hard reset on it with all cables attached?
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
are you sure it's not turning on---i.e. iTunes does not recognize it? It would be much more likely that it's just a backlight problem.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
I meant to update this sooner. I just unplugged the new screen,let the battery die and when I plugged it back up and ten plugged the device in, the screen powered on as normal. Not sure what caused it to do that, but I'm glad it's working now. Thanks guys!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
April how long did you wait for your battery to die? I am in this same situation and I dont know what to do..
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Lauren--letting the battery die out is the same thing as doing a hard reset---hold the power and home button for 10 seconds.
A hard reset often solves a lot of iDevice problems. If a hard reset doesnt solve, your next step is trying with a known good screen--i.e. your old screen to make sure the problem isn't a defective new screen or torn/damaged flex cable. If that fails to solve, then think backlight problem on motherboard.
jessa
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
April 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 499
