Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3313 질문 전체 보기
No service after water damage iPhone 5
Hi,
I have a water damaged iphone 5. I've cleaned the logic board and changed the screen. The iphone has now NO SERVICE. When i put the sim in, i have to give my code and then the iphone start searching after a minute "no service"
I've tried with other antenna without succes.
What causes this problem and how do i fix this?
thx
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글:
Baseband is fine, thx for the reply
의 답변
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
4개의 답변
선택된 해법
Water damage is horrible you don't no what part it's wrecked.
you could buy all the parts and it still might not work. Motherboard damage is mostly the cause
Update
Have you tryed a restore?
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
가장 유용한 답변
Check in the system setting to see if the IMEI and ICCID are properly displayed, if they don't display, the baseband is not powered up or fried.
Then we go to RF check, check for visual damage and power on the transceiver and each amp, signal routes for each band, the details can list more than 5 pages so it is a tiring process
해당 답변은 도움이 되었습니까?
점수 5
댓글:
Where can I find the 5 pages ?
의 답변
의견 추가하세요
I will assume you've ruled out a time/date thing after battery disconnect. Toggle airplane off/on and connect to WiFi.
Last one I had like this was latte damage that I had to desolder the SIM tray to see, it ended up a baseband power ic problem and I gave up. The next one freaked me out with the same behavior so I thought it would be the same. It was jailbroken so hard to see the carrier info. I worried about it for half and hour before I realized it was the silly time/date thing.
keep us posted when you figure it out.
jessa
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Putting it in a bag of rice won't clean the logic board. Clean the logic board with isopropanol and check again
해당 답변은 도움이 되었습니까?
점수 -1
의견 추가하세요
귀하의 답변을 추가하십시오
Mattis 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 21
지난 30일: 130
전체 시간: 36,907
