not Chargeing after screen repair
Hi, anybody.
charge symbol get active, but do not charge after screen replacement.
phone say charging but battery still not charging... help.
dock is clean.
좋은 질문 입니까?
Hi, anybody.
dock is clean.
좋은 질문 입니까?
hi, yes i just changed the dock/charging socket/assembly.
up and running:-)
해당 답변은 도움이 되었습니까?
Did you disconnect the battery?
해당 답변은 도움이 되었습니까?
Sounds like u have knocked or damaged a componant off the board have a look and see around the battery connector
yes, battery was disconnected, after disconnecting home button.
tried to reconnect again, and changed back to original display.. no charge but phone acts like it!s charging.
If phone acts like it's charging and isn't then it's definatly board damage
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 247
댓글 4개
Dear Jan,
did you solve the problem?
I have the same problem... After a screen replacement battery don't charge even if the charge symbol is OK; I have not disconnected the battery connector on the logic board!!
Any tricks?
Thank you everyone in advance,
Mauro ju Macniaco
Mauro Macniaco 의
UAu!!
You had changed this one:
iPhone 5s Lightning Connector and Headphone Jack
I'll try to change...
Thanks
Mauro Macniaco 의
Mauro Macniaco did you manage to solve the problem?
I have the same issue.
Thanks,
Jake.
Jake 의
Got the same issue and perplexed as I checked connections multiple times. Is it apple rejecting the new screen hardware ?
Murali Varadarajan 의
