The PlayStation 3 Slim is the second version of the PS3 video game console produced by Sony Computer Entertainment. It was released September 1, 2009.
315 질문 전체 보기
PS3 Slim YLOD 50/50 before reflowing, 0 after.
Hi,
I have a PS3 Slim that suffers from the YLOD.
Previously the YLOD was a 50/50 chance of occurring.
The PS3 would still eject discs if there are any in the slot then YLOD and turn off, the HDD indicator will flicker orange for a short duration before YLOD as well.
The same characteristics are exhibited when the HDD is removed from the set.
On the other occasions when it boots past the YLOD phase, it works with no problems and i can continue gaming as if my PS3 doesnt have any issues, for hours on end.
Using elimination, i concluded that the issue was not coming from the HDD nor was it due to a heat issue as my PS3 would run for hours and not overheat. (good ventilation).
Earlier tonight, i did a reflowing for my PS3, after that, reapplied thermal paste, closed it up and the PS3 YLODs immediately on power on, with & without HDD and it will not even eject my disc.
General inspection of my PS3 Slim is that it is clean as a whistle otherwise. I thought after 4 years plus it would require cleaning, but i guess keeping it off the ground drastically reduces the amount of dust.
I have triple checked the ribbons and cables to ensure that everything is as it should be.
Sorry to trouble you, but would you have any advice for this to bring my PS3 back to a running state?
Also, for this occurrence are there any other factors that i might be missing as well?
Thanks for your time.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
I would try again, paying special attention to the reflow, really concentrating on that particular part of the repair. Sounds like a bad reflow.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Russell W 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 1,422
