No power after new battery!
iPod TOuch 4th gen no power after new battery all contacts are soldered on...what is wrong?
좋은 질문 입니까?
좋은 질문 입니까?
I just shorted it...now the tip of my finger is burnt and black, and so is the resistor. Thanks a lot. Now the entire board is toast!
해당 답변은 도움이 되었습니까?
iPod was sold for a few dollars, as a brick.
have you plugged it into itunes to see if it is recognized? You may to bridge that one contact with the charging dock, this is an issue on the 4th gen whenever you open it and remove the screen/battery.
해당 답변은 도움이 되었습니까?
iTunes does not recognize, just replaced the battery with another new one, still doesnt. Ill try the short and put it all back together and see what happens
The iPod is getting really hot but still has no power...trying the shorting method.
HELP! How do I short the contact and dock connector? Im using a wire but dont know where or what to short...thnx
So I Jumpered the filter per this diagram http://d3nevzfk7ii3be.cloudfront.net/igi...
The computer made a ding noise (device removed from usb) and thats it...huh?
board was getting hot then stopped and cooled off...after jumper board is warm but not hot...tried shorting the charging system but didnt work unless im doing it wrong HELP
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 135
