주요 콘텐츠로 건너뛰기
널리 사용되는 인기 Galaxy 제품 라인을 비롯한 여러 Android Samsung 휴대 전화, 구형 및 신형, 수리 안내서 및 분해도.
13099 질문 전체 보기
Power button doesn't work on Samsung Galaxy Trend?
I tried the holding of the volume button ad putting the usb in, but it does not work on my device. is there any other way to turn it on?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
가장 유용한 답변
Hello.
Try next steps (apologize for my english, i'm spanish :) )
Hold Volume down and home at same time. Then, plug in the usb cable, previously connected to computer.
The device must go to download mode. Then, unpush both buttons, and press volume down to cancel and restar the device.
Worked for me in Galaxy trend, Galaxy S2 and BQ.
Good luck.
Please, tell me if worked.
해당 답변은 도움이 되었습니까?
점수 8
댓글 4개:
Thanks alot. I'm in the office, I would have been stranded!! Bless you. PS: You're English is good, don't worry :-)
It worked. :) Thank you so much. I had to plug in the USB cable with my mouth because I was using my other two hands to hold the volume down button and the home button.
I have a black Samsung Galaxy Trend Plus gt-s7580
OMG IT WORKED! I kept finding for tutorials on youtube but they still dont work. Thank you, you are my savior! :D
Brilliant !!!! Are you somehow related to Ethan (Mission Impossible)
댓글 달기
What does it do when you plug it in to charge? A lot of times, plugging it in, turns the device on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The volume down n home button trick works very fine. Thank you very much
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You are supposed to have someone help you.
Hold the VOLUME DOWN key and the HOME key then plug the USB. Will power up instantly.
댓글 달기
귀하의 답변을 추가하세요
jasnajasna934 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 4,039
