주요 콘텐츠로 건너뛰기
HP Compaq model dx2000MT desktop personal computer.
2 질문 전체 보기
pick up speed for hp desktop dx2000MT
please advise what to do in order to speed my PC HPcompaq dx200MT betambah,, thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Here are some general tips on how you can speed up your computer!
  1. Make sure all updates are current on your computer www.windows.com helps a lot
  2. go to your control panel and select the option to clear up disk space
  3. either search in your Start menu or in your control panel for ms.config and deselect all programs you don't need upon start up. you can find out crucial programs you need at www.bleedingcomputer.com/startups
  4. fix any possible registry issues. this can be done at www.glaryutilities.com/gu.html
  5. uninstall any programs you no longer need on your deskstop
  6. defrag your computer in your control panel
  7. run anti-virus, anti-spyware, malware, ad-ware programs that help get rid of all virus's and other issues that may have found its way to your desktop
  8. in your My Computer, right click on the drives and select properties> tools> error checking> fix errors.
  9. next you may want to upgrade your RAM. To do this you can go to http://www.auslogics.com/en/turbo-window... here you'll find an excellent article that makes it easy and smooth for all your RAM upgrading needs.
  10. once everything is said and done, create a restore point so you can revert back to the basics should anything bad happen to your computer that can be easily prevented with this method.
Hope this helps! ~Gadget~
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
taufik 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 2,372
