주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
Power & Sensor Replacement Problem
I have a Iphone 4 At&t phone that had a broken screen and power button would not work. I replaced the screen and everything worked fine and once my power & sensor cable came in I replace it following the tutorial and video on here.
At first I thought that I had killed the mother board since the phone would not boot up. I connected the mother board on another iphone and it worked fine. So i decided to connected just the charging dock, and screen cables to the motherboard can connect it to my laptop. It turned on so then i decided to connect the front facing camera. That also worked, now I connected the power ribbon to the board and it doesn't turn on, but when i do disconnect it i turns on!.
So what can be causing this? Am i missing something?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Power ribbon is faulty get another and you should be grand.
Disconnecting is messing with the connecter somehow and turning it on
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Replace the flex cable of power button and proximity sensor cable too.
Then try will work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jose 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 129
