Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
200 질문 전체 보기
Upgrading 1TB fusion drive to 3TB
Hi there!
Does anybody know if I can simply swap the built in 1TB drive in my imac for a 3TB and still have a fusion drive? Or are there any restrictions?
(iMac Intel 27" EMC 2639)
Thanks!
Thomas
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
2개의 답변
선택된 해법
Yes & No.
Yes you can swap out the HD with a new drive. But you will loose the spanning of the data between the SSD & HD (Fusion Drive). So you will first need to backup all of your stuff, then you'll need to break the fusion drive back to two discreet devices. After that you should be able to swap out the HD.
Now you do have a different issue unlike the older systems (pre '12). Apple altered the HD cable and uses a built in thermal sensor in the HD. So you will need to get a drive that is compatible. This is were you can't use a 3TB drive presently. I don't know of a 3TB that would work for you.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Dear Dan, Thank you!
Very helpful!
해당 답변은 도움이 되었습니까?
점수 0
댓글:
No problem! If this answer answered your question please remember to mark it accepted.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Thomas 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 568
