주요 콘텐츠로 건너뛰기
PowerMac G5는 Apple Corporation에서 2003년에 처음 제조한 데스크톱 컴퓨터입니다. 이 안내서는 2004년 Apple PowerMac G5 모델 번호 A1047 EMC 2061의 수리 과정을 검토합니다. 2006년에 먼저 개발자에게 그 후 소비자에게 Intel 스위치의 일환으로 판매가 중단되었습니다.
197 질문 전체 보기
Is my mac's hardware causing problems?
My Power Mac G5's specifications can be viewed here, since the panic attacks are extremely long.
I have recently had the following problems:
1. Mac showed a blank screen ( this lasted a day, connecting to the second port on the Mac fixed it ).
2. My Mac has at least 30 damaged SUID files says were damaged and will not be repaired.
3. No versions of Flash Player will install, even on different user accounts.
Is any hardware in my Power Mac G5 damaged?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
선택된 답변
The latest crash was caused by Stainless Client - that may be why flash won't install. I know nothing about Stainles, but, the linked page says "Although Stainless cannot make up for the dismal performance of not being able to have the latest Flash player on PowerPC" so that makes me consider that it might interfere with flash. The second to the last crash and others before that were caused by Core Audio.
Irrelevant reports of Damaged SUID files (you don't list them) are a "known issue" with specific machines and OS's.
I'm a volunteer so I didn't look beyond the first two incidents… maybe someone else here will, sometimes fixing one or two things solves or uncovers other issues.
You know your Graphics Card is suspect or damaged (using second VGA? port). That's one piece of hardware you could replace if you have a known good card to try. I don't know with a machine this age if I'd go buy a new card unless it was less than $50.00 (how much money do you want to put into this dinosaur?)
Try booting from the original install, and repair disks.' 'Run Apple Hardware Test. Come back with results and please USE THE COMMENT LINK to reply to this answer.''
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Lucas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 243
