2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
856 질문 전체 보기
Why CPU fan runs at full speed?
Hi Guys!
I have a problem with my macbook.
Few months ago I replaced my spilled keyboard and after that iSight camera doesn't works anymore.
Today I decided do fix it. After disassembly I noticed that there is some deformed pins in camera/wifi connector. I fixed that and after booting my mac I was surprised - the camera works. I make a FaceTime call and camera really works great, without any problems. But later i noticed that CPU fan spins at max (sounds noisy) and CPU runs at only 796 MHz all the time. I was trying to boot with unplugged camera connector but it doesn't helps.
Please tell, what can I do with it.
Thanks.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
3개의 답변
선택된 해법
I've done all resets (SMC, PRAM) few times but doesn't succeed. Then I decided just to completeley reassemble my MBP to make sure that everything is clean and well connected. And OMG, it work fine so far. Thanks for your replies guys.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
You should apply new thermal paste to the heat sink and stop using the laptop until you do.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
There is no overheating on GPU or CPU, all temps are fine. Thanks.
의 답변
의견 추가하세요
Sounds Like battery trouble. Is the battery ok? Did you try a SMC reset?
해당 답변은 도움이 되었습니까?
점수 0
댓글:
My battery is really old and has only about 50% of health. But it's not the main problem. Thanks.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
soldvit 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 200
