Apple은 2880 x 1800 해상도의 새로운 화면을 장착한 MacBook Pro 15" Retina를 출시하였습니다.
1710 질문 전체 보기
Battry not Recognized after Liquid Spill
Was given a dead 2013 15" macbook pro that was dead due to liquid spill. Removed motherboard and cleaned with 99% isopropyl alcohol. The macbook came back to life! Everything worked with the exception of the left "Shift", "Control", and "option" keys. Additionally, the battery icon say "no battery available". I ordered a new keyboard, and a new battery. After installing new keyboard and battery I still have the same problem of the three keys that don't work and battery not recognized and not charging.
Installed Coconut Battery and the program crashes when launched.
Interested in knowing where the charging circuit is on the logic board.
If you are going to say something like take it to Apple. Please don't bother commenting.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
Had you looked around you could find many possible answers here. No amount of cleaning will cure physical damage. You have either missed corrosion spots, or more likely, the liquid blew out components on the board.
I know of no way other than the Mark-1 Eyeball & and a magnifier to identify swollen or shorted (burned) components. This is a very advancedl DIY project. Desoldering and soldering of logic boards requires special tools, solder and lots and lots of practice. Unless you have much experience and knowledge in small electronic/computer repair IMHO it's a job best left to a professional. There are vendors on e-bay who claim to repair/remanufacture damaged logic boards.
You can remove and replace the logic board (an advanced DIY repair - difficult but not as impossible as repairing a damaged board). It requires complete disassembly and reassembly of the entire computer.
Same with the keyboard replacing the top case assembly (easy) or just the keyboard (masochistic) are the two solutions to your key problems.
If this answer is acceptable please remember to return and mark it.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Daryll 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 166
