주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2376 질문 전체 보기
Why can't my iPhone 4s restore?
Recently I have replaced my Iphone 4s screen and everything worked perfectly fine right after I had assembled it. After about 2 hours, my iphone 4s turned off twice. The first time, I started it back up and it worked. The second time, I was hopeless and the screen would not start back up. Later, I tried to connect it to Itunes and it can't restore because of error 21. I've tried literally everything (redsnow extras, modify hosts file, ipsw file, replacing battery, and DFU mode). Can someone help me resolve this problem?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
Error 21 is a battery issue if the phone is rebooting or switching off by itself it's battery.
Had error 21 on a few iPhones that customers brought in and a new battery fixed it..
All you need is a battery and jack is already geting you to replace the motherboard lmao
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Have you tried another computer? See if it works on that. If using DFU on another computer doesn't work, then your logic board will need to be replaced.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
if you replaced the screen and the device went off, then it could be the screen which sucks to much energy and that could damage your iphone.
plug the screen off and restore with that opened iphone.
if that doesnt help, i hope you will only need a new battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Anh Nguyen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 5
전체 시간: 1,477
