주요 콘텐츠로 건너뛰기
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
295 질문 전체 보기
connecting charging port ribbon cable to circuit board
How does the charging/docking port ribbon cable secure to the circuit board the ribbon cable seems like it was glued with epoxy or somthing .not sure ..way to small for solder..it was originally attached flat to the board...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
The charging port ribbon cable comes with it's own adhesive, so it can be glued on.
You can see the link of dock connector flex cable replacement, the area with blue film is where the adhesive on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had to remove the motherboard to check this out the other day. It is soldered to the board. Not glued.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
greg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 749
