주요 콘텐츠로 건너뛰기
A basic GSM Technology cellular phone from 2002 with accessible SIM card.
2 질문 전체 보기
Why will my cell phone not charge?
The cell phone will not charge. I have tried several power outlets to rule out the chance of a malfunctioning outlet. How can I fix this problem?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Andrew Corriveau, the very first thing you want to do is to change your battery. They are still readily available and inexpensive. You also want to make sure that your charger works on the output side. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I actually wouldn't change the battery until you say what kind of phone you are using. Do you mind updating up on the type of phone you are using. If it is a iPhone 5 series or greater, are you using mfi certified cables?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Andrew Corriveau 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 321
